V6TBird87
Apr 2002
Severn, Md, USA
im thinking about running a pair of fan relays to control the stock fans in the TC
my question is, is it possible to still use the EEC to trigger the aftermarket relays?
such as using the signal wires for the IRCM to kick the aftermarket relays
1987 Thunderbird 3.8
1987 Turbo Coupe, 5-speed
www.foxthunderbirds.fast-go.com
aka Tbird232ci
2018 Mustang GT
1988 Turbo Coupe, 5-speed
aka Tbird232ci
Joe F
Jul 2002
Hawkins, Texas - USA
Why? Is the IRCM fried? Short answer is yes, you could wire up such a circuit, but to make it fail-safe like the one in the IRCM is you'll have to copy the IRCM circuitry. BTW, just FYI, the IRCM circuit is given in the tech article here .
HTH.
Joe F.
JR's Aerie - Our 3 TC's
V6TBird87
Apr 2002
Severn, Md, USA
yes, one of the relays in my IRCM is done for, and i would much rather run my own relays that i could replace, or modify in my own way, rather than messing with factory stuff
how would you go about mocking the factory system? i was assuming it would be like any other relay, hot in, ground in, signal, hot out, and i was hoping signal would be from the EEC
damn im the suck with electronics
aka Tbird232ci
2018 Mustang GT
aka Tbird232ci
TurboCoupe50
Chesapeake, Va
Actually there is no reason you couldn't remove the original relay(s) and run wires out to a external relay with a plug. The orig's have four connections, like most aftermarket relays. Only difference I know of is they have smaller pins to mount on the PCB..
1988 Turbo Coupe... Bright Red
1988 Turbo Coupe... Dk Blue(parts car)
1987 Turbo Coupe... Silver(To be sold)
1988 Turbo Coupe... White, 5.0 with Trick Flow heads
1988 Thunderbird... Lt Blue base model 5.0 Windsor Jr heads
1969 Fairlane Cobra... 428 CJ, 4 speed
1993 F150 Lightning... Black.. #249 of 5276
1993 Aerostar... (To be sold)
1993 Grand Marquis...
Why not just grab an IRCM or 2 at the JY out of a late 80s / early 90s Taurus/Sable. They are the same as the TC.
V6TBird87
Apr 2002
Severn, Md, USA
its just not how i want to do it, id prefer to have the external relays, especially if i decide to run some other fans, or something similar, i would be messing with my own wiring, rather than hacking up a factory harness
im trying to avoid messing with the IRCM's, id rather not crack into one, even though i have a spare, its just not something i want to tear into
id also hate to run a bunch of aftermarket thermostat switches and stuff
aka Tbird232ci
2018 Mustang GT
aka Tbird232ci
