Failing PRC Struts.....What is the best way to go?
TURBO100 Offline
Got some good use from the PRC. Time to replace or upgrade. Currently Stock setup. Will settle for replacement PRC front Struts w strut tower brace.
Currently doing research for upgrade. Really like Koni's. Appreciate any input.
88 Blk Auto TC 3" Exhaust w magnaflow. 86 Blk Mustang SVO.
The Devastating Duo.
RK87TC Offline
I've got a set I'm not using any more. I put on MM coilovers. I've run it up the street a few times now going through shakedown mode...and the car feels like its on rails!!....If you decide you want PRC's back on again and can't find them close by..PM me...I've no idea what it would cost to ship them to CA.
Ralph
TURBO100 Offline
Are your Cobra 17" on adapters? You satisfied with the MM k-member package?
