Extending Turbo Life?
Blade1433 Offline
How can I reduce the amount of wear my turbo takes? I know about keeping the oil changed regularly. I was thinking about a turbo timer, but since it runs the engine after it's turned off(or just the oil pump?) it'll keep oil flowing. What else? Some kinda valve (memory lapse)?
Blade
"Drive it like you stole it"
88 bone stock TC with 138k, 5spd, burgundy in color
Why don't you do a survey here and turboford and see how many people are using the turbo timer. I think you will find that not many/any one uses it. You don't need unless you want to turn the car off immediately following a hard run. Driving down the street at legal speed for two minutes accomplishes the same thing. The engine has to run or the pump can't turn.
DrPhang Offline
ok.....
Dont drive hard if you are getting ready to park.... I know that sounds weird.
Just let the car idle for 30 seconds or so before you shut it off so the oil can get back to the bearings. The oil pump will do it's job.
You could spend $100 to $150 on a "styleish" turbo timer then then again that $100-$150 could get you some major hp from other things =) !
congrats on fixing the car man.
Blade1433 Offline
Thanks, I got all but the lower two exhuast man/turbo bolts off but then I had to go to work. I told my dad not to do it, I'd like to myself when I got home. Nope, he finished it and put the new one on, with out me. [Image: frown.gif] It's my responsibility to remember how the vacuum lines go, I don't. Tommorrow, I'm going to finish it off and have some Hondas for breakfast!
Blade
DennySweet Offline
Damn Dads!!! Don't ya love em!
88TC,87TC,,86S-10,82Toyota 4WD,3-88S-10Blazers.
wwwtbirdforumcom Offline
what does a waste-gate do???
Here is my 1988 TC, Clean look - Glad to be here...
[email protected]
Here is a pic of my baby
Here is my 1987 TC, Mean look - Glad to be here...
[email protected]
[Image: Cumberland.gif]
Blade1433 Offline
Denny,
How could you not? He's the only one who supports my, uhh, addictions
James
Blade
Turbocruiser88 Offline
The best way to keep a turbo healthy is to use it sparingly... ROFLMAO [Image: rolleyes.gif]
Les T.
88 TC - Light Sandalwood/Black 5sp. *RIP* Precision SC-50, A237, Stage 3 clutch, Ported E6/Intakes, 54k motor
94 BMW 540i
92 Saab 900s Vert
82 Stang GT - T-Top, Soon to be 2.3T - that engine shown above!
80 MB 300SD - Turbo Diesel
96 Explorer - 5.0 GT40 AWD, Soon to be turbo'd
Blade1433 Offline
Good sense of humor. Lol. Say, wanna come over tomorrow and help me remember which vacuum lines go where?
Just call me or drop on by, I have no life so don't worry about me not being home
Blade
Nate K Offline
"The best way to keep a turbo healthy is to use it sparingly... "
Yeah do like Les does, use it sparingly by keeping it under 100mph, just do 95 in a 55 LMFAO!!!
One of the absolute best things you can do to preserve not only the turbo life but the overall engine life is to run synethic oil. Alot of us (me included) run Mobil 1 synthetic. Personally, I run 15w50 during the warm months and then drop back to 5w30 in colder months. I've got 165k on mile #1 TC and my oil is pretty clean at 5k oil changes.
Conventional oils literally get cooked by the turbo and will cause coking.
Also use a high quality oil filter (not Fram either). Unless you've never seen cut-away sections of filters you don't know all the sales hype behind some filters. Use Purolator or Wix filters, they are far better than most on the market for the money. Don't believe me, by one of each, cut them in half each way and look at the filter elements and the inlet/outlet holes, then make your decision.
90 Mustang LX 5.0L Notch
Cars I wish I still owned:
69 Coronet 440
70 Torino 351C
79 Bronco 351M/400 on 35's
79 Trans Am 403 (6.6L)
88 Cougar XR7 5.0L
