Experts i need help, Keyless entry reprogram.
Noname
Unregistered
Ok guys, my new bird has keyless entry but the current and previous owners dont know the codes, How can i reprogram them to work. i dont really feel like spending an afternoon punching in numbers to make it work. only reason i ask is driverside Keys wont go in.
Turbocruiser88 Offline
There is a code for you on the underside of the trunk lid. Check along the sides of that. That's your easiest. Also, there may be one under your dash and/or glove box. Check your trunk first. [Image: smile.gif]
Les T.
88 TC - Sandalwood/Black
Torquer cam-valves ground-lifters/springs, Garrett T3-20 PSI w/intercooler, 2.5" single exhaust-Dynomax, Black/Gold engine detail, Light Blue Granite dash trim-White Gauges (100MPH-7k RPM-24PSI) *Currently has more blow by on the rings than out of the turbo*
88 TC - Strange Dark Red
Stock motor, crappy interior, decent body
Les T.
88 TC - Light Sandalwood/Black 5sp. *RIP* Precision SC-50, A237, Stage 3 clutch, Ported E6/Intakes, 54k motor
94 BMW 540i
92 Saab 900s Vert
82 Stang GT - T-Top, Soon to be 2.3T - that engine shown above!
80 MB 300SD - Turbo Diesel
96 Explorer - 5.0 GT40 AWD, Soon to be turbo'd
Gregg Offline
I read somewhere about being able to reprogram it..however, if you open up the trunk, and the passenger side support, the number should be there...also in the trunk, iuf you pull down the driver side (?) panel, the number is on a little sticker on the module for the keyless entry..
Gregg
TurboCoupe50 Offline
The keyless code for 87-88s can usually be found in two places. The first is on a small sticker attached to the passenger side trunk hinge. If its not there, the second is on the module. It is in the trunk on the driver side drop down panel(there are two panels, only one for the cars that do not have keyless/lighted entry or premium sound) . The panel is in the front area of the trunk, by the speakers. Just remove one screw it will hinge down, the 2x2x4 black plastic module is what you are looking for.
To reprogram(its not really reprograming, its adding a second code either will then work) you have to have the original code. To add the second code, enter the original code, press the 1-2 button then any sequence of five buttons you want to be your additional code. Make sure you remember the original though, disconecting the battery will eleminate the added code.
Three 1988 Turbo Coupes ..... yea one of em has a 5.0
[This message has been edited by TurboCoupe50 (edited 06-30-2001).]
1988 Turbo Coupe331 AOD
1972 Comet GT
Noname
Unregistered
Thanks guys, i appreciate the info [Image: smile.gif]
