Exhaust manifold bolts
w60 Offline
In my eternal "20 minutes per day" head gasket replacement, I'm about to bolt the exhaust manifold back to the head.
The threads on the bolts just don't look pretty and I'm going to buy new bolts.
I looked at Rock Auto and Napa so far and can't find them in either place. They look like a standard bolt that should be easy to find but karma just isn't with me.
Where can I find new bolts and studs? The book says they are M10 1.5 x 57
http://www.mycoachonline.com
White 88 TC Auto Trans
White 04 Honda CR/V
Blue 74 Honda Trail 70
Behind door number 1: http://natomessageboard.com/ubbthreads.p...Post224466
w60 Offline
"Thanks!" he said as he realized his pitiful attempt at searching on his own was, well...pitiful!
White 04 Honda CR/V
B Offline
I've had that stud/nut combo on my '86 for 6 years and never had an issue with any of the nuts backing off. :thumbup:
Ballman Offline
Just go back to a Ford dealer , parts Dept. can find them . Just make sure you know the size needed . D.Wilder
DW
bigep74 Offline
I actually found them at Lowes, I used stainless steel bolts with anti seize . The future will tell if this was a good idea......................
