Hi everyone,
I searched threads and found this one from 2008!
https://turbotbird.com/thread-turbocobra...motor+swap
I know you can build the 2.3 to run 10's. I'm thinking of swapping to preserve my stock 2.3L with only 95000 km on it.
I could buy another 2.3 and build it, but would like to install a 6 speed stick. I have found at least one individual that installed a T56 to the 2.3L.
There are many pullout options. I come across a 2.3 Turbo 310HP / 6 speed from a 2015 Mustang for 5KUSD.
Many years ago thought of putting in a 5L and twin turbo charging it. Later once I learned of the 4.6 Cobra motor thought of twin turbo charging it. The 5L from the era would be easier with less fabrication, but with owning a Mark VIII, I do like the 4.6.
I'm not against building a 2.3L, just in Mississauga I do not know of anyone that does great work on these cars.
I should mention that I need a new exhaust manifold and that is $409usd plus shipping and install. So just to fix mine and keep stock, i'm looking at spending around $800 CAD and think it better to put into some new?
Was also thinking of buying as it would come with the manifold, so only around $1100usd more for some serious HP. with the 5 peed. https://gnari.com/collections/turbo-syst...6943687174
but currently sold out.
88 TC
5 Speed
Custom 2.75" stainless steel mandrel exhaust, cross drilled rotors (KVR), 245 50 ZR Eagle F1 GS-D3 (front & rear). This tire works amazing with the PRC. Wet or Dry! Lowered 1.75 inches
5 Speed
