Engine sputters
Rosebuddage Offline
Hello -
Just put many $ into rehabbing my 88 TC, which I have owned since new. Running great until now - in the A.M. when I start her she idles fine upon driving away, she farts & bucks.- ? It's a 5 spd. anyone else out there have had this problem? Is it fuel filter related or what?
Original owner of my 1988 - fell in love then & cherish it now.
Could be ignition, fuel or sensors. What have you done so far. have you pulled the codes?
Rosebuddage Offline
Lets see - all coolant lines, brakes, valve cover gasket, full tune up, new radiator, heater core, alot! It pulls no codes believe it or not! So where does this fall from here!?
Nate K Offline
Check what Pete said, however it sounds like PIP or TFI (or both). Sometimes changing just one of them will cause the problem to increase because both items work together. It's recommended to change both at the same time.
See the Tech Articles for complete info on the TFI/PIP at http://www.turbotbird.com/techinfo/TFI-PIP/TFI-PIP.htm
[This message has been edited by Nate K (edited 09-30-2003).]
90 Mustang LX 5.0L Notch
Cars I wish I still owned:
69 Coronet 440
70 Torino 351C
79 Bronco 351M/400 on 35's
79 Trans Am 403 (6.6L)
88 Cougar XR7 5.0L
What brand of plugs and plug wires did you use and did the problem exist before the tune up?
Rosebuddage Offline
Everything I used is Motorcraft other than one item on the distributor that had to be replaced.
Noname
Guest
We should design an automatic message board feature that automatically replies to every new post with this question:
Did you make sure you securely connected both intercooler connections and tightened the hose clamps?
Under vacuum conditions, the rubber IC hoses might contract a bit and form a good enough seal to prevent a major vacuum leak, but under acceleration and the tiniest amounts of boost (or even low vacuum), these hoses might leak in / out air and screw things up.
If the car ran fine before this tune"up" and still idles normally, this is where I'd start.
Estoril blue 1987 TC 5spd, 141k miles
PRofec B electronic boost controller, kirban fpr, walbro 255 pump, Bailey BOV, Spearco 26x8x3 FMIC, a237 cam, t3/t4 50 trim / stage III .63, 3" exhaust, eec-tuner, 55pph injectors,
Best 1/4 mile: 13.64 (with 2.19 60' time) @ 102.91mph And that was on 93 octane Wink
Spooler87 Offline
I'd agree woth the IC hoses I thought I had mine tight, and it stuttered and sounded like it had a blow of valve....even the olacement of the clamps affects the seal.
87 Tubocoupe, Light Regatta Blue, All Options incl. Leather; 2.5" exaust, Dynamax super turbo mufflers w/3"chrome tips, MSD 6AL, Blaster2 Coil and wires, Homemade adjustable boost valve.
"The stage is set, the orchestra engaged.... it's now time to see if you can dance."
All hail Project "Marauder" !
Rosebuddage Offline
I must say that I am lucky to have you guys out there! I will check all of these to see what is up with this problem - I will keep ya posted. Thank you again so much, for I really love this car, I have since the day I bought it! Rosemary
