Engine sometimes stalls during sudden braking, please help!!!
Philip Stocker Offline
My 88 TC 5speed has a small yet annoting problem. Sometimes when I am coming to an abrupt stop, the engine will stall (fuel level in tank does not matter) Is the IAC causing the problem? I am planning on swapping in the ranger roller cam and maybe a 110-130 amp alternator, hopefully this might help.
Another thing, ever so often, while the engine is idling, the rpms will suddenly drop like it's going to stall, then the engine catches and runs fine
Any thoughts??
Philip Stocker
Blade1433 Offline
My guess is either a bad TPS(check faqs) or a serious vacuum leak. My car did the idle/stumble for a while untill it got so bad as to require me to hold the accelerator when I was at a stoplight or "idling" someplace. I'd check the TPS and the vacuumfirst. Sorry, don't know how to check for vacuum leaks...
Blade
"Drive it like you stole it"
88 bone stock TC with 138k, 5spd, burgundy, almost all options with new U-joints, tranny Xmember, front end, FULL tune-up with select MSD products, new horizontal axle shock thingies, custom interior, white face guages. Coming soon: boost guage and air fuel ratio guage on the pillar, Gillis valve, K&N, gutted upper, knife edged lower, gutted E6, T3, and steam cleaned engine bay.
When was the last time the car had a complete tune up?
A sticky IAC could possible cause the stalling problem. Since the cost to remove it and clean it out is zero, I would start there.
wwwtbirdforumcom Offline
Do you need to remove the intercooler to get at the iac removed???
NATO Paying Member
Here is my 1988 TC, Clean look - Glad to be here...
[email protected]
Here is a pic of my baby
Here is my 1987 TC, Mean look - Glad to be here...
[email protected]
[Image: Cumberland.gif]
Kev Offline
No way! The intercooler is in a totally different spot than the IAC. The IAC is the little cylinder (1 inch diameter, about 4 inches long) on the back of the throttle body next to the firewall right on top of the engine. It has two bolts holding it on and an electrical connector. Just totally take it off the car, be careful of the gasket if you don't have a replacement, and blast it with carb cleaner or WD-40 and use q-tips to clean it out. I ruined the gasket on mine and used a McDonald's french fry box to replace it. Just traced it and cut it, easy. Cleaning the IAC improves throttle response. Do a tune up with motorcraft wires and dist. cap and cheap copper plugs from Wal-Mart and I guarantee you will be able to tell the difference on your top end. Have your battery checked for the stalling problem, if your ABS is having to work overtime then it could drain the power going to your ignition. Do your lights dim when you brake hard? Check it out, even if that's not the problem then at least you know.
Kev
Kev
1988 TC 5spd
segfaultxr7 Offline
Haha.. That's great. I'll have to remember that one! We TC guys sure can be resourceful. [Image: smile.gif]
88 TC 5-speed
Blade1433 Offline
Kev, I wouldn't use the fry box, they are too thin and might wear out. I used the 20piece chicken nugget box for mine. It's corrugated so it's thicker and will last longer...
hehe
James
Blade
I did not think you could get a screwdriver in there because the intercooler seems to be in the way - that is why I asked about removing it...
[email protected]
SteveX82 Offline
Yeah, I had to use one of those stubby little screwdrivers to remove the screws on mine. If worse comes to worse, it only takes a minute or so to take off the intercooler, so if you need to do so, go ahead. Just make sure everything's seated properly and the clamps are tightened well before you drive away.
maroon 1987 TC 5spd, 128k miles
k&n mounted in front of radiator with 3" pvc piping, gillis valve set at 17lbs, kirban adjustable fpr set at ?, walbro 255 hi-pressure pump, crappyass rear tires
Best 1/4 mile: 14.857 (with 2.26 60' time)
Best trap speed: 94.01mph
I don't know about others but for myself, being a lefty, it's a lot easier to remove the IC to clean the IAC. If you are going to do a complete tuneup, it's got to come out anyway.
