Ok guys, I am sorry in advance that I can't describe this better. I am not technical.
I am driving my car. It seems to be fine all in all, except for the wierd electrical things... until this. I don't know what it is, or if it is a big deal.
I am going down the highway. The turbo engages (not a ton of boast, but it is an auto). I get to the "Cruising speed" of 65 or so. I generally drop the car into overdrive so that the engine is not running so high. The RPM will go from 3000 to 2000-2500. Here comes the problem. It seems like the engine "surges". The car does not jerk. It is not like that, but I can hear it in the engine. I can hear that it is reving higher and then dropping down. The RMP needle shows it as well. Not a ton, but around 300-400 difference. It is almost like when it needs to shift into another gear and then does not. It just makes the 'urrrr-urrrr' sound and it just seems that it is working too hard. It had not done this before, but I only have about 200 miles on this engine since it has been put into the this car. What is this? Any ideas? Please tell me it is not major!
I just want my Bird back!
