What's up guys? My bird is starting to piss me off. OK, just so whoever reads this knows the whole story, a couple of weeks ago I had to change my valve cover gasket (or camshaft cover, whatever it is). In doing so, I had to take my spark plug cables off and pulled a couple of them apart in the process, so I went and bought new ones, after I installed them, I couldn't get the engine started, I got it started once and revved it to about 2 grand to keep it running, but as soon as I let off the gas it died.
Well, one thing led to another and I had crossed the 3&4 cables, I had the inter-cooler off when I first started it and had to give it a little gas to keep it going, and it ran a little rough in the process.
So I put it all together and took it for a little test drive and had a real slight miss to it when I got it revved up around 3&4 grand and 80mph+. It was hard to start when cold too. So since then I have put new splitfire spark plugs, a new distributor cap, rotor button, along with the new wires I had bought, checked all plugins, elec. wires, vacum hoses, everything.
Right now, it's missing all over the RPM range, sitting still while revving it up, all gears, in just about all rpms, espically fourth and fifth between 2 and 3 grand. Could it be the gas I put in it? I'll run that out this afternoon and put a different brand in it and see. But any suggestions any of you can give would be great.
I do need to get this fixed asap. I'm getting ready to drive from Texas to Ohio, and that's a long trip to have to worry with the engine constantly missing. Thanks for all help given.
88 TC, all original nothing rebuilt, mods- Superchips chip installed, Splitfire sparkplugs, Bosch 8mm wires, K&N filter
future mods- cross drilled rotors, and performance pads, lower 1-1/2" in front;1" rear, upgrade tires to a hopeful 245s(if they fit)but probably 235s 45s in front and 40s in the rear, 17" Cobra R rims
