I have seen many repair manuals showing a bracket (similar to the one I have located near the distributor) for a lift point in the pass. rear area of the block, but my engine doesn't have one. Is this common or is it supposed to be there out of the factory? see pic link..
Anyways, I assume bolting the chain into the open thread hole where that bracket should be will be fine? Should there be two bolts or one will hold? Not sure I see and extra open hole for a second bolt.
Ron
Black 87 TC, 2nd owner since [email protected], [email protected]
