Yesterday I put a gasket on the rear end and refilled it. I also tried to fix the annoying leak around the elbow to downpipe flange, I wasnt really successful. I have no idea why that thing wont seal up. But I guess I have to deal with it til I get a new turbo, elbow, and dp.
Anyway, now today Ive been getting an intermittent CEL just idling, or even cruising. So I got the codes.
KOEO - 23 (separator) 41, 42, 72
I seem to always have 41 or 42 stored. Could my o2 be going bad? Or could a small leak around the DP flange cause false readings?
KOER - 23, 25, 26, 34
I got the 25 regardless of whether or not I smacked the intake with a 3/8 ratchet. KS is plugged in.
I saw the code 34 and took off the EGR valve and cleaned it out, as well as the little port for it in the intake. Then ran the codes again.
KOER take 2 - 23, 25
Still had code 25, could my KS be dead, or am I just not hitting the intake right? I always seem to get a 23, no matter how much I adjust the TPS, I adjusted it anyway to .95v and did KOER again.
KOER take 3 - 23, 25, 34
Lovely, insufficient EGR flow again. Oh well. Im done for the day.
Im surprised I only got code 26 on the first KOER test, If you check my other thread I just posted you will see that my VAM is way out of spec.
88 TC, 170k, K&N, $5 Boostvalve, Stinger 3" ex., 3" Magnaflow, 3" Stinger tail, Zoom clutch
15.26 @ 86mph, 2.18 60' killed valvetrain & headgasket
