enertia switch? how to disconnect it?
qmakowski Offline
how do you disconnect the enertia switch? do you just try to unplug it or do ihave to unbolt it from the car?
qmakowski Offline
ahhh where is the damn enteria switch! i cant find it!!!!!
What year car? If it is an 87-88, it is located at the rear, attached to the bulkhead the tail lights are mounted to. You have to remove the trunk liner panel to see it. You can unbolt it from under the car. If the car is 83-86, it is above the pas side wheel well in the trunk.
karnage Offline
If it's tripped then push it in.To bypass it just jumper it so it makes a complete connection.
qmakowski Offline
thanks, found it, replaced the fuel filter, all is well again... except for the trans, read my other post
