eliminating the equalizer
Sal Offline
How can I eliminate the equalizer? I have an aftermarket head unit, so I don't need it.
I'm going to mount guages in place of the eq.
Thanks
Stang8u Offline
Just take it out and make a plate
http://i1131.photobucket.com/albums/m550...9F21B2.jpg
:mad:
Sal Offline
Im trying to bypass the eq; how can I connect the radio to work without the eq?
tbirdx2 Offline
There is a second harness connector that will bypass the equalizer and connects directly to the speaker. You will have to search for it a bit. You can then remove the equalizer and install the factory block off plate.
TurboCoupe50 Offline
tbirdx2 Wrote:There is a second harness connector that will bypass the equalizer and connects directly to the speaker. You will have to search for it a bit. You can then remove the equalizer and install the factory block off plate.
This, it's usually in the upper right corner of the opening, be sure to disconnect the trunk amp or you'll get smoke from it(wanna see my T-Shirt?)...
BTW there is no factory block off plate, without the EQ there is a small storage well in it's place...
1988 Turbo Coupe331 AOD
1972 Comet GT
Sal Offline
Factory amp? I didn't know they came with one.
Where is it located?
In the trunk on drivers side drop down panel behind rear seat, sort of football shaped... If equipped, the lighted entry or keyless entry module will also be on this panel...
1972 Comet GT
