electrical problem
Tim Offline
i have an 87 turbo coupe, at first the clock stopped working, then the lights inside stopped working, the power seats stoppes working, and now the trunk lights stopped working. I've chased down wires, checked plugs and fuses and still can't find out why. If anyone has any ideas I would apreciate the help, thanks
Joe F Offline
First thing I'd check is the ignition switch; ours are pretty old and they do have a tendency to go bad, especially as old as they are. They also can cause some very strange and seemingly unconnected symptoms, sometimes changing almost on a daily basis.
The next thing I'd do, assuming the IS is OK would be to look at all the bower feeds starting at the battery and verify their solidity. You might also check the ground while you're there.
That should keep you busy for a few hours and might just correct your problems, good luck.
P.S. Moving to Electrical Forum.
