EGR valve Delete
BabyBlueBird Offline
Currently deleting my EGR valve, I notice the vacuum line coming off of the EGR valve is goin to what looks like a module and then a return line goes back to the vacuum tree. Does anyone know if I can just block off the vacuum tree port and leave the module connected? I can’t find anything on it or what it does.
Attached Files Image(s)
88Slowbird Offline
(07-10-2022, 03:36 PM)BabyBlueBird Wrote: Currently deleting my EGR valve, I notice the vacuum line coming off of the EGR valve is goin to what looks like a module and then a return line goes back to the vacuum tree. Does anyone know if I can just block off the vacuum tree port and leave the module connected? I can’t find anything on it or what it does.
yep I cap that port at the tree and unbolt that whole block from the car
it's just the EGR and overboost buzzer it won't effect anything to unplug them
Black 1988 TC: RR Cam (with Esslinger cam gear), Stinger FMIC, Stinger 3" Exhaust, .60/.63 SVO Turbo, Pimp V1.4, Spartan2 Wideband, Bypass Valve, Hurst Short Throw
Mach 1 Red 1988 TC: Steeda Tri-Ax shifter, manual boost controller
Thanks for the info.
Does anyone know the thread pitch of the Bolt that threads into the EGR valve
