egr recall?
charles88tc Offline
How can i tell if my car has had the EGR recall? Visual or can i check online somewhere?
JT Offline
You should have a small Ford recall sticker somewhere under the hood that states the recall was performed. Aside from the sticker, there will be an inline delay valve just before the vacuum connection onto the EGR.
Do you ask because you get Code 34? If the recall was performed on your engine, it generally will result in code 34 during the EEC tests, so it would be normal.
TurboCoupe50 Offline
JT... The recall delay valve seems to block vaccum completely to the EGR, or is it just really slow in opening?? Anyway I usually pull em off and toss em in the "spare parts bin".
Three 1988 Turbo Coupes .....
And now a 1987
1988 Turbo Coupe331 AOD
1972 Comet GT
Back in the late 70s, early 80s, when manufacturers were trying to meet emission standards with carbs and there were miles of vac lines under the hood, delay valves were common. It was also pretty common for them to plug up, preventing the "flow of vacuum". In several applications, replacing delay valves was a part of factory scheduled regular maintanance, just like changing the oil.
Ryan H Offline
Is it okay to just bypass the recall? Would it have any effect on emissions? Could it possibly get better gas mileage after that, too? I guess it'd be putting more unburnable stuff into the intake, right?
Ryan Harris
1988 TC 5 speed, all options including sunroof, Star stage III. Currently installing: Walbro 255 LPH HP, Kirban AFPR, 3" DP to 2.5" duals, bypassed cat, Magnaflow mufflers Smile
