EGR
ZeroRain Offline
ok now i was looking at bob long's headers and i was wondering exactly what does the EGR do do i need it on my 88 TC
Drive it like you stole it
1987 Turbo Coupe Auto- gone
1991 Sport 5.0 Auto- gone
1996 LX 5.0 5spd- Gone
1989 Super Coupe 5spd- gone
1984 Turbo Coupe 5spd- newest project
Did you reads the EGR articles in the FAQs?
ZeroRain Offline
no but im going to now
Boostbird16 Offline
even after reading that article it doesn't tell what would happen if you were to remove the egr system. sounds like all that would happen is your exhaust might be a little dirtier. I removed my egr system and didn't notice any changes in the way it ran/consumed fuel. however, not every car is the same. just my .02$
Adam Rafferty
Joe F Offline
And it can decreas your gas milage a bit, too. Also can increase combustion temps.
Joe F.
My 87 TC & mod list with sources
Glenn 88TC Offline
It could cause you to fail emissions tests if you have the testing in you area. He does offer his log header with an egr bung welded on it. If you want to see what the result of running without the egr would be you can just pull(and plug) the vac line from the valve.
mods: SDS Digital Fuel Injection, ported & polished big valve head(1.89/1.59), .500 lift roller cam, custom upper and ported lower intakes, 60-1 stage III .63 turbo, powerstroke intercooler, 60mm throttle body, 75pph injectors, Walboro 255HP pump, Kirban adj. fuel reg., ATR header, 3" exhaust with Dynomax Ultraflow muffler, MSD 6al, MSD coil, MSD Launch Control, MSD 8.5mm wires, K&N filter, Star stage III clutch, Greddy Profec B boost controller, Weld Draglites with M/T ET Street 26x11.5/15
[This message has been edited by Glenn 88TC (edited 04-04-2004).]
NO TC and NO headaches.
