eec probs
chrome302jr Offline
Hey guys, I been having probs with my eec display blinking so I ran the test and came up with a 01 code. I know theoretically that it means a blend door out of position...but what the hell is that and where is it located? More importantly, how do I fix it? THx for the info.
Ronnie
88 Tbird 5.0 [email protected]
88 Tbird TC slow....
I can send you an exploded diagram of the evaporator case which does show the blend door. I think?? the door is actuated by vacuum but it's position is electrically sensed. You may just need a new vac line or maybe a sensor connector came loose. This isn't something I have experience with so I really can't tell you more. E-mail me if you want the diagram.
Walsted Offline
Quote:Originally posted by chrome302jr:
Hey guys, I been having probs with my eec display blinking...
EEC (Electronic Engine Control Computer) or EATC (Electronic Automatic Temperature Control)? There are about three electrical connectors behind the glove compartment; it may be possible to jiggle a connector or two and get it to work.
Mike Walsted - Nato member
1986 5-speed TurboCoupe .
[This message has been edited by Walsted (edited 01-17-2002).]
If I remember correctly, the blend door is powered by an electric motor with feedback position control. The blend door is what determines the temp of the outlet air by blending hot air from the heater or cold air from the A/C with ambient temp air.
Asimov Offline
Sorry to restart an old thread, but if it's electrically controlled, why does it have a vacuum line running to it? (well, my 86 has one that runs through the firewall and appears to go in it's general direction)
thanks
-asi
1986 TC, 132k pretty well taken care of miles. k&n, [email protected], timing @ 8 (spout out), A/C delete. 3" Downpipe (no other exhaust... Whoever described that sound as a "pissed off tractor" hit the nail on the head)
[email pics to asimov at forced-induction org for sales/id/showoff purposes (free hosting)]
-asi
1986 TC, 132k pretty well taken care of miles. k&n, [email protected], timing @ 12 (spout out), A/C delete. 3" Downpipe (no other exhaust... Whoever described that sound as a "pissed off tractor" hit the nail on the head)
Walsted Offline
The Electronic Automatic Temperature Control is electrically powered. The manual climate control uses vacuum lines.
Mike Walsted - NATO member
1986 5-speed TurboCoupe with a few upgrades.
Asimov Offline
Thanks
-asi
