John B
Dec 2015
New Jersey
Ok, so I got the 10mm bolt that holds the harness to the ecu but how do you actually remove the ecu from the hangar bracket? Is there another bolt somewhere? Removing the stock ecu for a PimpX in case anyone was wondering. Thanks
Been 15 years since I pulled a PCM, but I seem to remember a small bolt clamping the PCM to the white plastic holder. Removing this bolt (maybe there is another one too??) and the PCM can be removed. Sorry I couldnt be of more help.
John B
Dec 2015
New Jersey
Jeff K Wrote:Been 15 years since I pulled a PCM, but I seem to remember a small bolt clamping the PCM to the white plastic holder. Removing this bolt (maybe there is another one too??) and the PCM can be removed. Sorry I couldnt be of more help.
Thank you; I believe I read somewhere that there's a 7mm bolt holding the hangar/bracket but I'm not sure where it is
BJL
Williamstown, New Jersey
10mm bolt and some moving around the harness.
i never put that bolt back in since i dont trust my LA3 since it popped a cap back in 2014.
Brian J Larkin
88TC 320k miles
89 Cougar XR7 3.8SC Auto
95 Ranger Splash 3.0 auto
