Thndrchckn420
Mar 2003
Winchester, VA
I read a post awhile back about cutting a hole in the trunk to create an access panel to the fuel pump...Wondering if I can get pictures or measurements so I can do this on mine. Was there anything under the area to be cut that I need to watch for? Thanks
88 5-spd. bypassed BCS, cleared cat, Gillis valve,ranger roller, no major mods yet.
88 5-spd. Precision SC-50 ball bearing turbo, gillis, full 3" exhaust w/ 3- 1/2 crome tip, ported E-6, ported big exhaust valve head, ranger roller cam, Essy cam gear, K&N cone in front of the radiator, gutted upper, knife edged lower, Walbro 255HP pump, Kirban AFPR, Forge BPV, PA Performance 130 AMP Alt...
dezridin2
May 2004
sunland C.A.
That sounds pretty hokey there thunderchicken,I wouldnt recomend it.Its pretty easy to drop the tank if you have a floor jack,That way you wouldent have to worry about water getting in your trunk.
To be safe, you would have to drop the tank to cut the hole.
Like dezridin2 said, dropping the tank isn't a big deal.
well no it isnt hard to drop it its just tedious sometimes to get under there and all break the bolts loose yea you get the picture
Its like wiping before you poop. It dont make sence.
1987 Turbo Coupe Auto- gone
1991 Sport 5.0 Auto- gone
1996 LX 5.0 5spd- Gone
1989 Super Coupe 5spd- gone
1984 Turbo Coupe 5spd- newest project
Thndrchckn420
Mar 2003
Winchester, VA
Yeah, y'all are probably right...just lookin for an easier way. Anything I should know before I drop the tank? Ive been reading a lot of posts about having to drop the tank several times after installing the new pump. Also, money is an issue...dont have enough to go hog wild on the car...what do you guys think would be a better way to go...porting or turbo? I know that with the stock IHI, porting wont help me too much, but am I gonna feel a lot of lag going with a bigger turbo before I get the porting done? Eventually, Id like to do both, but cant afford to do it all at the same time. Thanks
[This message has been edited by Thndrchckn420 (edited 07-02-2004).]
You will get more immediate results from a larger turbo. I think the thing is to not go too big until the rest of your system can keep up. Why don't you think straight T3 for now. Porting will be more benefitial later as you need more air flow capacity.
