Pat Fay
Jul 2001
Waterbury, CT, USA
Hey, Does anyone know where I can get Dynomat cheap?
Pat
[email protected]
1987 Turbo Coupe
Mod's -
~ K&N 6" Cone mounted in front of radiator, JVC Kameleon CD Player, New Kenwood 3 1/2" and 5 1/4" speakers, New 6x9s, Blackout Lights in front, Gillis Valve set at 17 psi , Single gauge A-Pillar Pod w/ boost gauge, 2 1/2" dual exhaust from ATR but stock downpipe and Cat, downpipe and Cat will come eventually, Centerforce Clutch
**PathogeN**
Pleasanton, CA, USA
Answer...NOWHERE. Don't get dynamat. Theres this stuff called hi-temp mastic..its similar to dynamat but no name on it. I gotta look around for the site you can get it at tho.
87 TC 5-Speed. Medium Red/Red Leather. 5.0 T-5. Gutted & Polished Upper, Ported & Polished Lower Ported E6, Ported/Polished Head. Knifed TB Butterfly. Esslinger alum. flywheel, FMS SVO clutch & plate, Unorthodox drive pulleys, K&N Cone, VAM Mod, Dual 2.5 dynomax, teflon impeller'd 18k mile IHI, Brembo vented cadmium rotors & 2-piston calipers, Brembo lines & 4-channel ABS Computer. HPM Rear lower C. Arms, Griggs front A Arms & K Member, Max. Motorsports Caster/Camber plates, Eibach pro kit, KYB AGX Struts, Tokico shocks & quads, PST Polygraphite all around, Lincoln LSC anti-roll bar (f), 225/50zr16's. 2kWrms Infinity/Clarion Pro Audio Sound System
88 Turbo Coupe (White)
88 Psudo Coupe (Silver LX)
Pat Fay
Jul 2001
Waterbury, CT, USA
Would you recommend the spray or is the mat the best?
Pat
[email protected]
1987 Turbo Coupe
Mod's -
What is it???
SteveX82
Toms River, New Jersey
Quote:Originally posted by Pete D:
What is it???
It's a sound-dampening material that comes in rolls instead of that horrible foamy stuff
maroon 1987 TC 5spd, 128k miles
k&n mounted in front of radiator with 3" pvc piping, gillis valve set at 17lbs, kirban adjustable fpr set at ?, walbro 255 hi-pressure pump, crappyass rear tires
Best 1/4 mile: 14.857 (with 2.26 60' time)
Best trap speed: 94.01mph
Pat Fay
Jul 2001
Waterbury, CT, USA
I just put in two Kicker Comp 12" Subs in my TC but my trunk rattles alot now. So my dad had a roll of Heat and Sound sheild type crap, but that doesnt work at all. So I was wondering if I should get the Dynomat spray or just buy the mat?
Pat
[email protected]
1987 Turbo Coupe
Mod's -
