Dumb question?
jiggyincanada Offline
Still having overheating problem. But I noticed a little of what seemed like steam comming from under my innercooler. I think maybe a leak in hose or somthing. Question is can I pull off innercooler and let car run to check for leaks?
Thank,
Jiggy
OOPS! I BOOSTED, ONE TOO MANY TIMES, AGAIN....
DL1182 Offline
Banned
Well man,
To answer your question it is a no, you car will not start nor run w/ out the intercooler in place. The easly things too check thoe are the steel looking hoses the run too and from the trubo they may just need too be sured up.
Dave
'86 Cougar XR-7 TURBO. Fast as hell, 18-19 psi, on stock engine w/ adj. boost valve, and custom intercooler. My cat is sick now, fuel pump is going to call it quites any day now Sad Hay I'm on yahoo IM at DL1182; On AOL at DL1282; On MSN at DL1182
My email address is [email protected]
SteveX82 Offline
The car *will* run (albeit it irratically) without the intercooler if you disconnect the connection on the VAM, but keep in mind that your engine will not only be letting in unmetered air (because of the VAM being out of the connection), but it will also be taking in unfiltered and potentially harmful air. I would suggest either checking for coolant leaks the best you can while the car's running with the intercooler on or running it for a few minutes until the steam develops, then shutting off the engine and quickly removing the intercooler to check for any leaks. Either way, I doubt that a slight coolant leak would cause your car to overheat (especially during these cooler months and in canada). Have you checked the coolant level and to make sure the radiator fans are working? Either of those problems seem more likely to cause your car to overheat.
maroon 1987 TC 5spd, 125k miles
k&n mounted in front of radiator with 3" pvc piping, gillis valve set at 17lbs, kirban adjustable fpr set at ?, walbro 255 hi-pressure pump, crappyass rear tires
Best 1/4 mile: 14.857
Best trap speed: 94.01mph
Thanks for your input. Yes the fans seem to be working and coolant is up and ok. Starting to think it's the temp gauge it self or sending unit (which will be changed today).
Thanks on the IC question because my dad was just about ready to try it with it off [Image: eek.gif]
Jiggy
Here is my signature just to let you know who I am:d
Sorry guys [Image: redface.gif] Im just learning how to use this system. Here is mt signature [Image: smile.gif]
1987 turbo coupe bought for me by my dad. I am 16 and a girl who loves turbos! Car is bonestock (for now!)eh Plan on Gillis valve,K&N ETC>
I suppose you could get some rubber hose and run it between the turbo outlet and the throttle body to get it to run better. That way you could see the hose connections normally hidden under the IC. Just a way out thought....
Blade1433 Offline
"Uhh, hey baby"-Beavis
Gonna post some pictures of you and your car?
What are the details of your car? Color? Tranny? DETAILS!
Blade
"Drive it like you stole it"
88 bone stock TC with 138k, 5spd, burgundy, almost all options. Soon to have a pillar boost guage along with new tires, zinc plated rotors and a custom paint job
trbocoup Offline
maybe you have the same problem as alot of us have or had, your gauges lie to you! i forget what the part name is right now but, everyone else does because my brain is retarded today. lol
88 tc with many mods
88 tbird 351 w/paxton
88 lincolin lsc
loves to eat Uncle Bens 5 min rice rockets! mmmm mmmm good!
Just because you're not paranoid,....Doesn't mean they're not after you!
Hey blade1433,
My car is Grey,5 speed with all options including the cutest blond you will never see! 4 New blizzack tires (this is canada)and kenwood sounds. Red guts. Picture of me and car?? Maybe me and the car doing a burnout. Who Knows..Where are your pics?
THANKS,JIGGY
