Liquid_force
Aug 2001
Lawrence, KS USA
Problems at 5 or more psi -- No power, pops and backfires. Struggles to maintain 70mph uphill. Basically anything more than 1/4 throttle and it falls flat on its face.
Most recent codes:
KOEO -- 85,88 (These always show, don't believe they are anything important) I think Jeff mentioned it may have something to do with the fact that one of my cooling fans is no longer run by the computer.
Cont. Mem -- 42, 58, 66
KEOR -- 23, 73, 76 (I have reset the tps, idle is not perfect, but seems ok.
New stuff: Plugs, wires, cap, rotor, O2 sensor, timing belt and timing set at 12 deg. with spout out. Fuel filter is maybe 10K old, and fuel pump (autozone) is 2 years old (strainer was reused). FPR replaced 2 years ago as well.
It is PAINFUL for me to drive my car now. I'm desperate to get this problem solved. Help??!
88 TC -- Dark Blue 283k
RIP - 9/22/07
She was a great TC and went down swinging
85 = Electronic Control Assembly status - adaptive "lean" limit reached in fuel control program. This may be related to the 02 code, below, not sure?
88 = Fans
42 EGO - 02 voltage signal alays rich (high value)does not switch. This may relate to 85 above. The ECA is trying to lean the engine out because the 02 is always telling it the mix is rich. This may or may not be an 02 problem.
58 = VAT signal voltage too high (open connection in circuit). Was it 50* air temperature or less when you pulled the codes? If the temp was above 50* see code 66 below
66 = VAF voltage signal too low. This says the VAF is reporting less air than is flowing through the VAF. It could be that the connector to the VAF is bad or the VAF is bad. Check the connector for bent pins of pins pushed back
23 =- TPS sensor voltage out of self test range.
73 you didn't move the throttle far enough during the test.
76 Insufficient VAF sensor change detected during Dynamic Response Portion of Engine Run Self test. Probably relates to 73
I'm going to e-mail you a VAF testing procedure. It's similar to testing a TPS.
I'm also going to e-mail you the fuel systm diagnostics as part of the problem may be fuel related. Try curing the VAF/VAT codes first
Dan E
Greensboro, NC
Codes or not...these sound like classic symptoms of the timing being off. Like the Timing Belt is off the Cam Sprocket a tooth (or more).
Dan Eaves
Dan Eaves
I tried to e-mail you that stuff and it bounced, no reason given. E-mail me direct if you want it.
PsycopathicBird
Aug 2001
Crofton, MD USA
thats the same condition i had when i first got my bird. definatly check the timing AND the SPOUT plug--> for corrosion, pull it out clean it, then recheck the timing. check the fuel pressure too, i had a bad regulator too.
silver 88 TC with a new stock turbo, holley 155 fuel pump, gauge pod with a/f and boost, K&N cone, and a holley ignition control module, homemade air intake, bosch bypass valve, Single 3" exhaust, Gillis Valve, external Autometer fuel pressure gauge on hood, new falken 502s and stock replacement springs, ngk iridium plugs.
Bring on the track Baby!!
14.95 @ 91.8 so far....
[email protected]
86tc
Jan 2002
Jonesburg, MO, USA
Mine was doing the same thing since I got it, up until last weekend. It turned out that one of the plugs were shot. I mean REALLY BAD!!! I changed it out, and everything was fine. Runs terrific now! [Image: smile.gif]
Rick
'62 Ranchero (in progress...again)
'72 Gran Torino Sport (for sale/trade)
'76 Honda CB750 (for sale/trade)
'88 Yamaha Blaster Race 4-wheeler (for sale/trade)
'89 Lincoln Town Car (for sale/trade)
'92 GMC Safari Conv. Van (for sale)
'94 Pontiac Bonneville
'96 GMC Jimmy
Liquid_force
Aug 2001
Lawrence, KS USA
Sorry Pete, the e-mail I had on my profile isn't active anymore. I've updated it. You shouldn't have a problem now. And thanks for the help.
When I did the timing belt I had a guy helping me that was cutting a bunch of corners and I really didn't understand what was going on. Can someone describe what I need to do to make sure timing is correct? BTW, when I adjusted the timing it seemed to idle smoother clear up at 30 deg. and as I backed it back to 12 it started what sounded like a slight miss. But--The problems I'm having were present before I put on the new belt (maybe not as bad).
The spout is the little connector just down line from the distributor right? Just a little stand alone chip type thing? How should I go about cleaning it?
I'm pretty confident the FPR is ok.
What's an FP guage cost? A couple people have suggested I check that.
Rick
It's not a bad plug, that I'm sure of.
RIP - 9/22/07
Walsted
Fort Worth, TX
This one is simple. Rotate the crank until the timing mark is line up at zero degrees, TDC, and the rotor under the distributor cap is pointing approximately toward the number one plug. The cam timing mark should also be aligned at this point.
You made sure that your ignition timing was 10 degrees or so BTDC with the spout out, right?
Hope this helps.
Mike Walsted - NATO member
See the article "Cam Timing" in the technical article for a procedure a diagram. It it smoothed out at 30* ingnition advance, then the cam timing is off.
imjamesw
Mar 2002
Bakersfield, California
88 Medium Red Turbo Coupe. 172K. Stock. Horrible A4LD. 5k miles since 2006. She will be a part of my family as long as I am.
