Driveshaft fun!
Not B Anymore Offline
Replaced the wheel bearing which was bad, but I still had a vibration issue. Don't know why I never noticed it before, but I could also feel it in the shifter. After taking a short test drive and actually paying attention to what it was doing I realized that I had classic symptoms of a bad Universal Joint. First off let me say that it would have been much easier to do if I had the next size up Bench Vise! Anyways - as I was taking it all apart they didn't really look all that bad... until I got to literally the last bearing cap. Inside the last cap I removed it was completely dry, rusted up, there was probably 6 of the needle bearings left and the rest I suppose had been ground to dust!
These were pretty old, non-greasable U-Joints. Needless to say, I bought the new U-Joints with grease fittings!
Just thought I'd share.
B
thumper Offline
Not a bad job with the right tools; can be frustrating as well with the wrong ones.
Glad you got it fixed!
A.K.A. Corey Bennett
zbird Offline
Brian, I just did mine last month for the same reason. I also had a vibration. I had 2 bearing cups on the rear joint that were nothing but dust. It now feels like a new car!
Dom Z
99 F150 4x4
14 Ford Escape 2.0L Turbo
gmaibach Offline
i bent 3 good wrenches on the driveshaft bolts... gettin the bolts out took longer than the u joints
1988 Turbo Coupe 5 speed Red with Red cloth interior, K&N cone filter, Ported IHI turbo, ATR Header ported, Manual Boost Controller at 18 psi.
2013 Focus ST 2.0 Turbo, Buschur green filter, OCD Speed axle back exhaust.
