mark murphy
Sep 2002
maumelle, ar. usa
My 88TC auto tranny has a vibration, starts
at 75-80 mph. I've had tires/wheels balanced so I'm guessing it's between tranny and axle.
I've only driven this car about 3000 miles since I bought it in July.(currently has 61,000 miles) The tranny was jumping in and out of O.D. when climbing a hill or under a load which I now know is typical of these autos. I had new fluid/filter put in and that
has done away with the jumping I/O of O.D. I need suggestions how to trouble shoot this.
Hopefully one of you guys has had this problem. I can't push past 80 mph w/o
my butt getting a massage.( i can hear the jokes now) Could there be something else in the tranny that could cause this. It's got me worried. I'm seeing big dollar signs.
88 TC silver, 11/05 complete engine rebuild including head work, stainless valves, upper/lower intakes machined by Pete D. Added T-3 60/63 using Bob Lee 3 Gen. header, 3"downpipe no cat, 2-1/2" duals, adj FP Reg. Walbro 255 FP, cold air intake,Gillis boost valve, bypass valve, 3 row radiator, 17 x 9 Cobra R Wheels
Dan E
Greensboro, NC
Driveshaft ?
Could be off 180* as they are balanced...
Dan Eaves
Dan Eaves
oldone
Aug 2001
Panama City, FL
Had the same problem with mine when i purchased it. Spent some time trying to troubleshoot it and finally tracked it to the driveshaft. I couldnt see where any weights had fallen of but it smoothed out nice after it was balanced.
oldone
88 Maroon TC 5 speed
K&N Filter
Gillis boost valve
oldone
K&N Filter
Gillis boost valve
220,000 Miles
Kev
Harrison Arkansas
Kev
I had this problem once, same thing as the other guys...it was the drive shaft, only it wasn't out of balance, the bolts had loosened on their own! I could turn them with my fingers, I just put some locktite on them and tightened them really good. No more vibration.
Kev
Kev
1988 TC 5spd
Liquid_force
Aug 2001
Lawrence, KS USA
Had the same problem after I did the 5 speed swap. Had gotten my DS from a jy. $45 balancing and it's like new.
88 TC -- Dark Blue 283k
RIP - 9/22/07
She was a great TC and went down swinging
Chris Ruhl
May 2001
Oakley,M.I.,48649
Could be a bad bushing in the tailshaft of your tranny. That is my problem.
Kev
Yup, pretty common problem on RWD Fords with the 7.5 and 8.8 rears. For some reason the bolts that attach the DS to the companion flange on the dif like to loosen up on their own.
