Hi
I need to get a new drive shaft for an '84 TC. The engine mods I did apparently bent the original.
Does anyone know if a Mustang drive shaft would fit, or does the Thunderbird have different dimensions?
Or, has anyone had a custom drive shaft built--any recommended vendors?
Thanks!
Dale
anasazi4st
Feb 2015
Phoenix, AZ
(09-20-2023, 05:06 PM)DaleLeo Wrote: Hi
Thanks!
Dale
There is a place here in Mesa, a city here in the Valley of the Sun where I got mine, custom made. I can’t see where you are located, but unless you are within a few hundred miles or so there has to be a place closer to you. Shipping would be pretty expensive I would bet from here.
88Slowbird
May 2019
Tampa, FL
Thanks!
Dale
mustang will be too short the Thunderbirds are longer
you'll need one from a 83-88 Cougar or Thunderbird
also has to have the same transmission as whatever you have (you can't use an auto driveshaft with a manual trans)
1985 TC 5 Speed: Steeda Tri-Ax Shifter, Big R Stage 1 T3, Stinger FMIC
