Drillin the throttle body
Import Killer Offline
If I drilled a hole in my thottle body (the butterfly or whatever) would that drop my idle?
1987 Turbocoupe
Painted sonic blue pearl
Ground effects w/S351 wing
17x9 Chrome Cobra Rs
255/45/ZR17 Kumho 712s
KYB suspension
MOMO shift knob and boot
K&N cone air filter, Gillis boost valve, T-3 turbo, ported intake and E6, A237 roller cam, MSD coil, Kirban FPR
Full 3" exhuast w/Ultra Flo muffler
Brute force clutch
White faced indiglo gauges
2 12" Rockford Fosgate subs and amp
Probably not. Why do you want to drop your idle?
Well, after a few minutes of driving, my car idles at 2K i need it to drop and i cant figure out how
1987 Turbocoupe
KYB suspension
Brute force clutch
SteveX82 Offline
Did you try *setting* the idle? That's usually the best place to start before randomly drilling holes [Image: smile.gif]
Go here for the instructions: http://www.turbotbird.com/techinfo/idlet...tment.html
JO346820 Offline
My car for months was idling like crazy, going up to 2000 or above sometimes, randomly moving about. Replaced the Throttle positioning sensor ( TPS ) and fixed that, the engine light, and my random stalling when I was shifting into neutral.
-Joe
127k miles in January when I bought it for $200. 138k now. A few mods for more power in the planning. (:
dadsturbocoupe Offline
Wow. Please, in the furure, promise you will ask here BEFORE doing ANYTHING. Drilling holes in the throttle plate is way off. Would probably cause more 'imbalance' in the way the car runs, since these things are full of sensors that actually control how it runs. Ask here, and ye shall recieve..........good advice. Please.
87 5-sp, black/red leather. Every option but sunroof.
95 Impala SS Grey/green metallic(was wifes car) FOR SALE
91 Caprice wagon (tricked out for the wife-refused to purchase a minivan)
66 Mustang convt w/5.0 AOD conversion, 4 wheel discs.
73 Mazda Rx2, 220 H.P ported 13B (sorry-it'll pull a bird, unless she was really hopped up)
74 Chev 1/2 ton p/u completely gone through (cause ya gotta have something to carry parts in!)
All living in my 40X72X12 shop. Sweet.
91 Caprice wagon
73 Mazda Rx2, 220 H.P ported 13B 74 Chev 1/2 ton p/u completely gone through (cause ya gotta have something to carry parts in!)
71 Datsun 510, race car/street car, father/son project.
2000 BMW 540iT. Beautiful car.
Well i know we replaced the air bypass valve, i dont think i checked that out yet, ill try it. Oh yea, i wouldnt do anything crazy before asking the experts.
1987 Turbocoupe
KYB suspension
Brute force clutch
Drilling a hole in the butterfly will let MORE air in, which will increase idle speed even more!
DrPhang Offline
dude I would bet my nutsack it's the TPS I had the same prob! get a new one and calibrate it.
TurboE Offline
I agree with Jeff, more air = higher idle. I had an similar idle problem and it would stall in traffic situations because i would let off and push the clutch and brake and it would stall unless i put the clutch in, brake in, and sort of got the gas pedal to keep it running. I talked to a good ford mechanic that knows these cars, and he said clean the trottle body. So i got carb cleaner and sandpaper and scotch pad and cleaned the small amount of carbon from inside the trottle body and it worked perfect again. Seemed to be rediculous that would make a difference but it did. Try it, doesnt take long and its very cheap. Good luck.
-88 TC Black
-97 Pathfinder
