Downpipe Question
Noname
Guest
Ok, does the Sacramento-Mustang 3" DP for 85-86 SVOs bolt to an IHI easily? I've heard that you need to extend the bolts or something and I heard that it's made for a SVO style T3 so it won't actually bolt right up. Compared to the stock DP, how far does the 3" DP come back to?
1988 TurboCoupe - 5 Speed
6" K&N In Front Of Radiator, Gillis Valve @ 15 psi, Centerforce Dual Friction
[This message has been edited by dm22 (edited 10-22-2001).]
All that has to be done is elongate the flange holes (on the downpipe) very slightly.It can be done with a file, grindstone in a drill, whatever. It is no biggy.
