Double check my rear suspension plans
PsRumors Offline
I started cleaning up the 8.8 I picked up this morning. Plan is to paint it this week and install next weekend. Here are my plans, make sure I am not forgetting anything.
I want the car to handle!
CHE Upper double adjustable with rod ends
CHE Double adjustable lower arm Poly / Rod ends
Upper Control Arm Bushings (Differential side)
Maximum Motorsports Coilovers
Which shocks? Will the MM work with Tokico adjustables?
Is the Pan hard setup from MM easier to do with the axle out or can I add it late just as easy?
Anything I am missing?
'83 TC - bone stock
'84 GT Turbo
V6TBird87 Offline
What coil over springs do you plan on using? That is really what determines what shocks to use.
2018 Mustang GT
1988 Turbo Coupe, 5-speed
aka Tbird232ci
PsRumors Offline
Don't know. Need to speak with MM, not sure on the rate etc.
'83 TC - bone stock
'84 GT Turbo
