whoever
Apr 2007
granite city IL.
Does the 87tc have seperate relays for lock and unlock? If so where are they? My doors will lock with the button but not unlock.BTW they do unlock with the keyless
01 DODGE DAKOTA 68 GALAXIE 500 FASTBACK 87 TURBO COUPE 89 Lincoln LSC
DonH
Jun 2002
Central Massachusetts, USA
Yes. The relays are beneath the passenger seat. If it unlocks with the keyless entry the relays are OK and the problem is with the switch. Did you check the other switch on the passenger door?
1987 TC stock except ATR 2.5"
whoever
Apr 2007
granite city IL.
It won`t unlock with either switch. Ill have to check power and ground at the switches and post what I find. thanks for the info on the relays anyway.
turbospoolin23
Jan 2007
Canada,AB
Bump... I am having the same problem with my car, my doors will lock with the buttons but dont unlock with the buttons. The relays are beneath the passenger seat?
Kev
Harrison Arkansas
Kev
Try firmly repeatedly pressing the unlock button. Chances are you hardly ever use the unlock inside the car and the contacts are just a little dirty or crusty. This happened to me once, and it still does ever now and then if I don't use the unlock button. Several quick taps on the button shakes the dirt loose and they function again. Maybe spray some contact cleaner on them if you care to take the piece apart.
Kev
1988 TC 5spd
turbospoolin23
Jan 2007
Canada,AB
Thanks for the reply Kev, Somebody suggested this to me before( tapping the botton) and i have try it on several occasions. Still won't work. I will take them apart and spray some contact cleaner on them and see if that works. IMO i don't think that is the problem though because both driver and passenger switches will lock with the buttons but dont unlock.
Any other suggestions?
