Door Lock Motor
Alaskanzeus Offline
Kind of just having a feeling of mine justifed, but over the winter the passenger door has to be giggled or continuelly pushing the door locks to get the passenger door to unlock. Is the motor shot? It wont open anymore now, the buttons on both sides work though.
Joe F Offline
Does it lock the door? When you try to unlock can you hear it "clunk" a little? Could be something as simple as the door lock mechanism as a whole needind to be lubed.
Joe F.
My 87 TC & mod list with sources
Another common problem is the rubber boost that fits over the rod / top of the motor rots away, allowing dirt and moisture to get into the motor / rod assy causing it to bind. If that is the case, the motor / rod assy can be cleaned, lubed, and the rubber boot can be replaced by the finger of a rubber glove secured with tie wraps.
Hurff Offline
There seems to be a fairly common problem that I dont think you have, but just in case....
The motors on these are fairly hardy, but they can carbon up and fail to work reliably. In a small nutshell, you can open the case of these, scrape & clean the brushes and commutator (no sanding) and re-seal the case to hap most work good as new.
If you need to go this route, let me know & I can get you more info.
1987 TC - RIP
BJL Offline
Moderator
I have a feeling mind is binding up , it wont even let me lock the door manually, any way of fixing that r shoudl i replace it?
also could i get info on clean the motor and brushes, seems liek that can work n the motor s in my 86 stang thanks Hurff!
Brian J Larkin
1988 Turbo Coupe 5spd
dark blue metallic
gillis boost valve, k&n cone,AFPR, 255lph HP pump,3G 130amp alt, 3.73 gears,mild torquie cam, factory DP, 2003 mustang take off SS mufflers and custom BJL 2 1/4 tails.
(out os service due to my idiot self)
88 TC Auto, med gray met. raven/gray interior, fully loaded miuns leatehjr and sunroof!
converted to N/A 2.3l, but its a nice driver with working A/C!
Brian Larkin
88TC 330,000 miles
Slightly Modified
Hurff Offline
Sure, I will get the one I have here apart, document it and try to have it back up in the next day or two...
1987 TC - RIP
Alaskanzeus Offline
It used to make that "clunk" noise for a few months, until all of a sudden it stopped moving in either direction. I used to sit there and continuously push the buttons till it finally worked. I thought it was frozen or something cause it wouldnt work until the car warmed up. So after it stopped moving I had to open the door manually from inside now. Have to push down with some pressure to lock it to. Also it was really hard to move in the lock position using the key.
