GlassRooster
Jan 2004
Ashland, VA
Mine are faulty the upper clip falls down so when I close the door it hits the post on the door jam and gets stuck to the point that I have to tear the rest arm and door trim off and take the assembly all the way out What a pain.. Will it ever stop oh well.. are junk yard replacements OK or are the replacements avail.?
David
87 TC Faded Burgundy with faded red interior
K&N and cold air ducting- rest is bone stock
02 Mazda Protege 5 Replaced Dead Saturn
99 Cougar- Wife's car new body style now Discontinued.
Turbojet
Feb 2002
Connellsville, Pa. USA
Did you check your hinges, maybe they are worn and making your door sag?
The Family:
86
87
88
servingGod
Feb 2003
Millersport, OH, 43046
"rest arm"
is that kind of like an arm rest. [Image: biggrin.gif]
88 TC 5-speed maroon, all options, plus t3/t4 hybrid, 255 pump, RR, Centerforce DF with weight fingers, MSD tfi coil.
88 TC 5-speed Black, all options.
88 Thunderbird LX 5.0 All options except Leather.
87TC Parts car five speed all options.
GlassRooster
Jan 2004
Ashland, VA
lo..l you are screwin with me Serving.. Been a long day. I feel like Job (the Bible dude that took a beatin)when it comes to my Tbird.
David
GlassRooster
Jan 2004
Ashland, VA
Bless this board and all that help
David
philS
Bellingham, MA
A junkyard replacement should be fine. I don't know about new ones - I've only seen the striker bolts for sale (autozone).
Click here to beat a ricer.
Hurff
Jul 2003
Annapolis,MD
ahhh, door lock assembly, not door lock actuator.... I was responding to a non-working acutator, which I can tell you how to fix, but thats not your problem...
Note to self: Must read issue better before responding...
[This message has been edited by Hurff (edited 04-06-2004).]
1987 TC - RIP
Hybridbird
Aug 2001
Rockford IL
Are you talking about the actual latch assembly that catches on to the door striker?Did yuo try to clean it ou treal weel with WD-40 or brake parts cleaner and then lube it back up with white lithium grease?Some times the grease that is on them get old and gets so much dirt and crap stuck to them,they start to bind up.
"Finch....get the f*ck away from that fikas......that is a jizz-free fikas!"
GlassRooster
Jan 2004
Ashland, VA
YUp pulled the whole assembly out of the door sat at the picinic table in the back yard with a beer or 3 and cleaned and lubed it. BUt I think one of the recoil springs was damaged and now doesnt have the strenght to pull the latch hook back 0utta the way completely when I open the door so when I close it the hook drops down and hits striker bar and jams. Then I have to lift on the outside door handle and use a screwdriver to to pry up the hook.
David
