Door hammer
Eric Offline
Hello Gents,
Long time no speak. I took my 87 out of gararge after sitting most of winter and like usual had to have multiple things go wrong. I have fixed them all except one. I closed my drivers side door and the plastic bushing around the door latch pin (I'm not sure of the exact part name)shattered. It is possible to replace, or is this some part the has also been obsoleted? It really make a bit of noise now because the door rattles a bit with out that bushing in place, also sounds horrible when closing the door. Any iadvice would be helpful.
Black 1987 T-Coupe 5 speed, stock xcept for K/N air filter.
lonstar7 Offline
Is this what you need?
http://www.autozone.com/autozone/parts/1...hyglZ8ijp2
Lonestar7
Eric Offline
Yes sir, that is it! Next time I'll try looking first!
Thanks!
turbobird63 Offline
Hey Eric, I took some 1/2"( i think it was 1/2") clear REFRIGERATION HOSE and cut it to length of the striker bolt and split it down the side and used liquid nails to hold it and that solved my problem. I think it cost me .29 cents. I had the liquid nails lying around.
Christopher Taylor
85 TC, 2.3l, LA3, T3/T4 Turbo 25psi, Stinger FMIC, Forge BOV, Full 3" Exhaust, Esslinger crank pulley- Timing Gears and overdrive WP pulley, BBK 255lph FP, Kirban AFPR, Kirban Shifter, K&N Cone, 3g Alternator, Energy Suspension Bushings throughout, CHE LCA's, Welded SFC's, and TON's of other parts.
turbobird63 Offline
BTW the only reason I did that was I couldn't find one of those strikers. Since now I see where to get it I think I may just go get one.
Christopher Taylor
KentCT88TC Offline
I bought those Dorman aftermarket door strikers and they made a world of difference in how tight they close and how they sound when they close ---"clunk".
-KentCT
-'88 Turbo Coupe, K&N, Gillis valve @18 lbs., 2.5 " exhaust.
-2000 Mustang GT 373 gears, Diablo computer chip, cold air intake, Typhoon intake manifold.
-2001 Jeep SE 2.5, AEM cold air intake, Gates headers & exhaust, throttle body spacer, Jet Stage 2 chip
Eric Offline
I had made quick stop at a local auto parts store near me just to see If they had part....they did...told me 20 bucks!!! Now I'm not cheap but after seeing this for half the price I could not buy it, I'm going to auto zone....thanks for saving me the money!
