KentCT88TC
Oct 2006
Beacon Falls, Connecticut
Couldn't stand the thick layer of dust on my black T-Bird. It's 10-15 degrees in Connecticut, so there is no way I can wash it. Took it over to the cloth automatic car wash in town this morning, and had them do it. Gave the guy who wiped it down a tip and everything. Was really happy, until I saw this fine line of scratch marks running straight down my trunk--where that little wheel goes. Now I am going to have to compound it all out in the Spring to try to restore it. Careful folks! -Kent
-KentCT
-'88 Turbo Coupe, K&N, Gillis valve @18 lbs., 2.5 " exhaust.
-2000 Mustang GT 373 gears, Diablo computer chip, cold air intake, Typhoon intake manifold.
-2001 Jeep SE 2.5, AEM cold air intake, Gates headers & exhaust, throttle body spacer, Jet Stage 2 chip
turbotronic
Oct 2004
Stillwater, OK
I've gone to this Advanced Car Wash place here in Stillwater a couple of times and it doesn't use brushes. It uses some technology (whatever) called RainMaker. It's pretty good, other than both times I have been through it, it has blown my left rear signal light bulb. The tail light assembly is not on completely nor sealed well. It has 4 options, cost ranging from $5 to $8, $5 being express and $8 being advanced (the works). I wouldn't mind going back to this car wash...after fixing the tail light. :p
~Mark
88 TC (Black), 5 speed
FMS 140MPH Speedo
Oval Port Head
1.59/1.89 SS Valves
APC Cone (I know...Ricer part)
Gillis valve
TurboXS BOV-RFL
Alum. Water Pump
Walbro 190
3G
88 TC (Red) [Parts Car]
xcrunnerbd
Oct 2006
Woodland, MI, USA
The last time I went through one of these - as a passenger in a '70 GTO Judge - it took off the rear spoiler. I vowed after that I'd never take a car through one.
Project 13 sec. / 30mpg in '88 TC 5Speed : 15.91@89mph / 32+ mpg
On The Car: KN cone, 2-stage Gillis@ 15psi wired to fuel switch, Kirban AFPR @ 39psi, Walbro 255 HP FP, 130A 3G Alt., Full 3" Stinger Exhaust incl. cat. no muffler,
Shelf: .48 T3, ported E6, BPV
GoNYYankees02
Dec 2004
Jacksonville, FL
Yeah, this frigid CT weather isn't making things easier..
I go to the local automated car wash and use the touchless with the under body spray on my truck. Because nothing actually touches it, it wont scratch it and it cleans it up pretty well. I wouldn't even think of using the regular one, just my .02.
88 TC- under construction. Street/Strip toy.
93 F250 7.3L- D/D
93 Jeep YJ- Offroad Toy.
06 Sportster 1200
03 FXDWG Anniversary-not stock
MeAndMyT
Sep 2006
Dearborn, Michigan
i go to the DIY car wash in my opinion i think i clean my car better then the 8 dollar top of line carwash.. Too many times have i heard of people coming out of carwashes and either loosing there antenna or getting scratches on there car..
edit: NYC i dont wanna sound stupid but does your truck really run on vegetable oil?
88 TC 5 spd 22x,xxx miles Ran 15.3 in 1/4.. K&N Cone. Gillis boost controller @ 15. Faze Boost Gauge. A/C belt off. 2 1/2 inch exhaust dumped at axles.
1BadBird
Mar 2005
Espanola, NM. USA
MeAndMyT..... LOL.... If you follow him too closely you'll gain 5 pounds from the smell
JK GoNYYankees02 How's it run on the veggie oil??
86' Blue Turbo Coupe (resto-mod in progress)
86' Black Turbo Coupe (will remain mostly stock.........maybe)
MeAndMyT
Sep 2006
Dearborn, Michigan
i talked to my step dad today and he said diesels do run on vegtable oil. pretty weird.
They sure do, and the exhaust smells like french fries! Veggie oil and similar fuels derived from plants is called boidiesel these days.
KentCT88TC
Oct 2006
I think they require a special heater to keep the frying grease from solidifying, but it's a great idea. -Kent
-KentCT
