(This post was last modified: 11-05-2023, 11:27 PM by anasazi4st.)
I am about to start the DIY IVR project, as it’s probably physically impossible for my TC to have as much fuel in the tank as the gauge shows—and the Temp and Oil Pressure gauges are also unrealistically high.
After getting the OEM DIY apart I was surprised to see an adjustment is possible—rudimentary as it is. While I am 99% certain that the DIY one—as documented by vegas_ss and based on the one developed by Jeff Korn and Gary’s Garage Mahal, I am curious if anyone has ever tried to adjust this using the screw shown in these pictures here:
https://www.dl.dropboxusercontent.com/sc...p02r4&dl=0
![[Image: IVR-PHOTO-2.jpg?rlkey=0fssch6xuc33hfovmm2zp02r4&dl=0]](https://www.dl.dropboxusercontent.com/scl/fi/i9b6zpvhxinga1htbj61a/IVR-PHOTO-2.jpg?rlkey=0fssch6xuc33hfovmm2zp02r4&dl=0)
https://www.dl.dropboxusercontent.com/sc...f5w3p&dl=0
Admittedly unless you have a lot of patience, this adjustment is probably something you would not want to attempt. I wonder—out of curiosity, again—if there would be a way to test this out of the vehicle?
Such an adjustment might be helpful if you don’t want to attempt the DIY fix.
![[Image: IVR-PHOTO-1.jpg?rlkey=iguty7f1lss29ab2hn0uf5w3p&dl=0]](https://www.dl.dropboxusercontent.com/scl/fi/ishxvko94sgqvflos336a/IVR-PHOTO-1.jpg?rlkey=iguty7f1lss29ab2hn0uf5w3p&dl=0)
