Distributor
Noname
Guest
I have a problem. Yesterday I was changing my cap and rotor, on my 87 TC. But the cap bolts were so corroded they broke. So I drilled them one out but the other side were the bole goes through was broke. Now when I start my car it'll only run about 4 sec than die. If I give it gas in the beginning it dies quicker. Could It be the cap isn't exactley in place or what?
I don't know if that's why the car won't run,
it's possible. I have broken those ears off the dist. I had to get a rebuilt. I use antisieze compound on the dist. cap bolts.
segfaultxr7 Offline
Seems to me like the cap would pretty much stay in place even with one ear broken off. Does it wiggle around or anything?
Are you sure you have the wires on in the correct order? Firing order is 1-3-4-2 and the dist. rotates clockwise.
88 TC 5-speed
The cap will cock to the side with only one bolt holding it, and teh car will run like crap. Dont ask me how I know this!
Noname
Guest
I figured out the problem. I had some wires disconnected and that's why it didn't run. My bad
