Will a duraspark distributor from a pinto work with a turbo engine. Not doing this for my TC. Just have a chance to buy an almost complete 2.3 for next to nothing. It has no wiring or ECU and I was thinking of trying to build a blowthrough or pressure box setup using a carb just to see if I could get it to work using a duraspark ignition in a pinto or fairmont.
I realize there are going to be issues with figuring out timing advance and running lean on the top but if it will go in and be able to fire I would be huge steps ahead compared to finding the wiring and ECU. Also I realize that I will probablt have to change gears also.
Thanks
Gordon
Thanks
Gordon
