distributor
gmaibach Offline
does anyone have a distributor for sale my reman ones suck so i said f it
1988 Turbo Coupe 5 speed Red with Red cloth interior, K&N cone filter, Ported IHI turbo, ATR Header ported, Manual Boost Controller at 18 psi.
2013 Focus ST 2.0 Turbo, Buschur green filter, OCD Speed axle back exhaust.
gmaibach Offline
will a n/a 2.3 one work? i found some on ebay from a jy with a 180 day warranty for 40... it says it fits but its from a ranger
N/A dist is the same.
I probably got 1 or 2 around here. Let me know.
Paulie Offline
Banned
What is the defect SIR. Is it electronic or a mechanical ISSUE. If its a mechanical issue BUSHING problem i have a FIX Thanks
gmaibach Offline
its completely shot it probably has about 1/4 inch of sire to side play and the shaft is all chewed up.... ill take one right now if the price is good
gmaibach Offline
I went through 3 reman and none of those fit right and the cap wouldnt fit right
You need to check the aux shaft also. If the dist is that bad, the shaft and it's gear may be defective also. If the shaft/gear is bad, it will just tear up the next dizzy. It becomes a vicious cycle. They need to both be right.
Paulie Offline
Banned
10000% true pull the aux shaft and replace it and the DIZZY.
50RACER Offline
I have a distributor from an 87 that was running great when I pulled the motor from a car that I was parting out. $65 shipped to you?
87 TC Medium Canyon Red
88 TC Black Beauty
