Diode and idle problem
Keith Nubel Offline
Could a defective diode in the wiring for the idle air control cause an idle problem?
85.5 TC 5 speed, Ranger Roller cam, 3" exhaust system, manual boost valve, large VAM, SVO PE computer, front mount Motorsport intercooler & sport grille, ported upper and lower intakes,flow matched injectors, ported E6 manifold, 245/45/17 wheels & Tires,140 mph speedo,Motorsport lowering springs, under restoration
1985 TC
Shorted diode will make the IAC inoperative or nearly inop. and could possibly take out the driver in the EEC. Open diode will not really hurt / affect anything. It is just there to protect the EEC from voltage spikes as the IAC dithers, even though the EEc has protection diodes on the I/O circuits to do the same thing. If one lead of the diode is disconnected, it can be checked with a DMM.
Keith Nubel Offline
I know they flow current in 1 direction, but how much resistance should it have?
1985 TC
Put DMM on a high resistance range, like 200K ohms or so. With one polarity, resistance should show infinite (overload, etc, depending on the meter). With the other polarity, should show a few to a few hundred ohms.... all depends on how much voltage the DMM applies during resistance measurements.
Qwertys Offline
most dmm's have a continuity/diode check. it should tell you either the forward resistance, or voltage required to forward bias the diode.
'85 TC BPV and Ford FMIC
