Anybody have any idea why all of a sudden I have started to get detonation under heavy acceleration ?
Nothing has changed in my set-up. I haven't checked my timing to see if it moved yet. I was running around 15* BTDC base timing and 18 lbs of boost with no problems up until now. If anything with the colded weather I'd think that it would detonate less ???
I plugged my KS back in today and it helped some.
Bad tank of gas maybe ? I always use BP 93 Octance Premium Switch on. I filled up again today so we'll see...but that's my best guess so far ?
Other ideas ?
Dan Eaves
Other ideas ?
Dan Eaves
Dan Eaves
