w60
Dec 2011
Birmingham, AL
w60
My 88 TC has an almost perfect interior and as summer creeps upon us I'm terrified of the dash cracking. I don't have a garage to keep it in (working on building one, but lot's of other $$ priorities now), so anyone have any thoughts on how to keep a dash from cracking? My 84 went 10 years in AZ, FL, TX and AL till it got a crack and I don't want this one cracked EVER!
lonstar7
Jun 2009
Round Rock, TX
I'm pretty much in the same boat, we have extremely hot summers here. When I got my TC 2-1/2 years ago the dash was good except a 1-2in hairline crack starting at the corner of the drivers side speaker. Within a year that crack expanded all the way back to the edge near the instrument panel cover. Although that 1st crack got longer, I've not had any others develop so far. I don't have a garage but I
keep it covered or parked in the shade in the summer and use a windsheild shade anytime it's parked. I also have been using a vinyl cleaner/treatment that's supposed to keep the dash from drying out and cracking. I put it on about once a month in hot weather. We'll see how things go this summer, but so far no more cracks(knock on wood!)
Lonestar7
Rub it down with Vaseline, I know sounds gross but google it and it comes highly recommended. Also like lonestar said keep it out of the sun with sun visors , trees, etc.
zbird
Jul 2008
Joshua, Texas
Mine cracked and now looks terrible on the drivers side. I eventually will have it restored at considerable expense. Take care of it the best you can.
I have heard that mineral oil works fairly well also to keep them from cracking.
I've been experimenting with mink oil for a few years, but the car is garaged most of the time and always has been. Mink Oil a great conditioner and softener for leather. What ever you use, use care around the defroster outlets and speaker grills on top. These areas will be more brittle than other areas
Nsw
Apr 2004
Vancouver, British Columbia. Canada
Nsw
+1 for mink oil. I used it to treat every thing leather from my work boots to the interior of my car. That stuff made my dash, shift boot and door panels look brand new. If you do use it test it on a small inconspicuous spot. All though it has not happened to me, there is a slight chance it can dye your leather.
w60
Dec 2011
Birmingham, AL
w60
leather? aren't dashes covered in vinyl?
Yes they are vinyl. And when it drys out it cracks, kinda like leather. At least that is my theory and why I'm experimenting with the mink oil. You can get it at Tractor Supply or shoe stores or goggle it.
lonstar7
Jun 2009
Round Rock, TX
I guess there's a lot of possible ways to do it. The main objective is to keep the vinyl from getting dry and brittle so it's elastic enough to expand and contract with temp. changes and not crack. I personally have tried some oily products before but the residue looks bad to me and it collects dust and dirt quickly. I also didn't care for the way some of the products smelled, probably had something to do with the petroleum based chemicals in them.
I've been using these products on my cars and Truck for 3 to 4 years and so far the results and good and they leave no oily or sticky residue and have a good, clean smell.
http://www.autogeek.net/1z-einzett-vinyl...ctant.html
http://www.autogeek.net/wg2700.html
There are a number of other similar products that I haven't tried, you can read about some of them here.
http://www.autogeek.net/rubbervinyl.html
Lonestar7
