dash lights
Harvs Offline
All of a sudden my gauge cluster, and climate control lights do not work. I checked the fuse but it was fine. Is it a breaker or something?
1988 turbocoupe with 88k, t3 super 60 turbo, disconnected KS, 3 inch down pipe no cat, with 2.5 inch ss ATRs, adjustible FPR, 255hp fuel pump, star spec stage 3 with stage 3 pressure plate, dual pillar pod with a/f and boost gauges, 3.90 gears, 140 speedo, hurst short throw, and GN intercooler
cheapbird Offline
Check your lightswitch assembly. Sometimes the connectors can heat up and cause problems.
Or at least, so I've found on Fords.
Harvs Offline
I looked over everything and i cant seem to find whats wrong. I'm not to good in the electrical department so you guys have to bare with me. Its a good thing my car is not on the road or i wouldnt be able to see how fast im going at night. lol
I'll send you the circuit.
