Dash Crack
LorainO88 Offline
Here we go. The dash gremlin finally conquered my dash. It started small at the defrost vent and literally within a week it was all the way diagonally across the dash to the far right of the speedo cluster. I hear this was even very common 25 years ago. Since a new dash is not optional and if I could find one, it would most likely be well over $500. I saw a seller on eBay that was asking that about a year ago. I'm sure he got it. Any recommendations? I looked on Rock Auto and Stock Interiors. They have options. Anyone out there have anymore? I'm looking for something to install over the original dash. I have a pad & I am just not very impressed with it. Thanks again for all the great advice. You folks are so knowledgeable.
WRBjr
squeeky Offline
http://www.americandashcaps.com/ymm/prod...&Year=1988
88 turbocoupe, gillis valve, k&n, short throw shifter,3" exhaust with magnaflows,Garrett(turbonetics) T3,AFPR,18lbs boost for now.....
^^^^ +1000
Get the dash cap. Pretty easy to install, and if installed correctly, no one will ever notice it unless you tell them. I have had one in my TC for 17 years, and it still looks perfect.
anasazi4st Offline
I don’t have a dash cap, but ordered a DashMat before I picked up my car at the dealership years ago and installed it right away. (I don’t believe they had dash caps 20+ years ago...?) Anyway here in the desert it’s a must-have. Despite that, when I installed a new heater core a while ago i had to temporarily remove it, and saw that I had many cracks in the dashboard. Oh well. Can’t see them with it installed though...obviously.
Perhaps I’ll take a look at a dash cap. I’ve been happy with what I have, though, for years.
