Dash cluster
Turbocoupe55 Offline
The speed and the rpm and the water temp are not working is there someone out there that repairs them and do it right ?
Actual gauge failure in TCs is very rare to unheard of. Much more likely to be just be poor or loose connections at the cluster connectors. Pull the cluster and disconnect / reconnect the cluster plugs several times and see if the instruments start working. If the fuel and oil pressure gauges are working correctly the problem is not the IVR.
Ok thanks I'll try it
