vegas_ss
Jun 2005
Las Vegas, NV
What is the type of bulb used to illuminate the headlight bezel? It is quite tiny and I can't see the number and I am unable to locate it in the shop manual. I noticed the old bulb was out, then removed and replaced it and it started working, then would go out when installed in the bezel. Now it won't work at all! It may be the contact wire on the bulb as it doesn't appear to be a short in the wiring or bulb housing (wiggle test), but I can't really tell and would like to try a replacement bulb if they are available.
If you are talking about the bulb that illuminates the blue indicator in the cluster when the high beam is on, it is just a #194 bulb, same as all the other cluster bulbs.
vegas_ss
Jun 2005
Las Vegas, NV
I was referring to the bulb that illuminates the bezel by the headlamp switch and lights up the headlamp text on the switch panel cover
88Slowbird
May 2019
Tampa, FL
I'm pretty sure they're #74 bulbs
1985 TC 5 Speed: Pro 5.0 Shifter, Big R Stage 1 T3, 3 Inch Downpipe, Stinger FMIC
vegas_ss
Jun 2005
Las Vegas, NV
(07-26-2021, 06:44 PM)88Slowbird Wrote: I'm pretty sure they're #74 bulbs
Yes Indeed! Picked up a pair at O'Reilly's and worked fine!
Thanks 88Slowbird!
88Slowbird likes this post
anasazi4st
Feb 2015
Phoenix, AZ
(07-27-2021, 12:06 AM)vegas_ss Wrote: (07-26-2021, 06:44 PM)88Slowbird Wrote: I'm pretty sure they're #74 bulbs
Thanks 88Slowbird!
Sorry, but if I might be so bold…why not switch to LEDs?
I have a complete list of the LEDs #s you’ll need to switch just about everything over from incandescent. (All but things like the OEM clock, whatever illuminates the digits for the EATC, etc. But most everything else.)
You should be able to do it for way under $100. The headlamps might be tricky as they were $40 but I think they’re gone up.
Jeff warned a few years ago to watch out for Chinese junk; try and get the Sylvania ones. I’ve had mine now for over 2 years and have had ZERO issues. I got mine through Amazon and I think most if not all are made in China. I think the quality of the manufacture has gone up considerably. I know I tried a few about 10 years ago and was very unhappy with the product quality and lifespan.
They run so much cooler and use a fraction of the electricity.
You won’t believe the difference. I won’t ever go back.
vegas_ss
Jun 2005
Las Vegas, NV
I was considering changing to LED, I did change the Headights a while ago but decided not to on the instrument panel as some of reviews I were reading seemed to indicate they don't last long and I didn't want to have to take the cluster out again if they may not last. I did get a box of 10 incandescent Sylvania 194's at O'Reilly's for under $10 and changed out most of the instrument cluster bulbs until I ran out. Polished up the cluster clear panel with some Mequiar's plastic polish and it looks very nice.
I'm going to build a SS IVR eventually and may try the Sylvania LED's out then. Did you just swap the 5 cluster illumination lights or also do the turn signal, high beam and other warning lights?
anasazi4st
Feb 2015
Phoenix, AZ
07-28-2021, 06:53 PM
(This post was last modified: 07-28-2021, 07:00 PM by anasazi4st.)
(07-27-2021, 03:35 PM)vegas_ss Wrote: I was considering changing to LED, I did change the Headights a while ago but decided not to on the instrument panel as some of reviews I were reading seemed to indicate they don't last long and I didn't want to have to take the cluster out again if they may not last. I did get a box of 10 incandescent Sylvania 194's at O'Reilly's for under $10 and changed out most of the instrument cluster bulbs until I ran out. Polished up the cluster clear panel with some Mequiar's plastic polish and it looks very nice.
*Everything* is swapped out. All incandescent lamps that I could access have been switched to LEDs. As I mentioned, some are not accessible—the clock and whatever powers the digits of the EATC are a couple of notable exceptions, there’s probably a few more (for example, thinking about it I don’t know if I changed out the tiny bulb that lights the ignition lock on the steering column).
But yes, all the IP lights—both illumination and warning ones—are switched over. Also map lights, dome light, opera lights, ashtray light, under-hood light, trunk light, etc.
I’ve had no trouble with my setup, and for many months I was driving to work in the dark early morning hours, so I had most all the lights on.
The only real concern is that many of the LEDs have to be inserted correctly or they won’t work. The POLARITY must be observed, as the instructions say. This is simply a matter of removing the LED and rotating it 180 degrees and reinstalling.
I’ve had no issues with dependability. Of course, read the reviews for a particular product to see if others have had issues with it, but that’s just common sense.
