Dash
sbhjr44 Offline
Here I thought I would get away with not having to pull the dash on either of my 87 and 88 TC's. Heater cores don't leak (but I do have 2 ford cores on the parts shelf) but wouldn't you know it the defrost decided to not shift to blow out the top of the dash. No room to see or really try to fix it with the gauges pulled and tape deck and EQ pulled and the EATC control and info panel out also. Well since I need to pull the dash to fix the defroster I will go ahead and do the heater core also. I really only want to pull the dash once.
Stinger dual3"exhaust from dp & cat to magnaflows w/2.5 outlets w/tailpipes.Homemade CAI w/boost at18psi.MM c/c plates and tubular lca/front coilovers with Koni red adjustables all around. Ported/BV head/A237 and bobslog w/a stinger fmic set-up waiting to go on.86 stang gt w/motor and T-5 from a 86 TC w/3"SS dualexhaust w/cc plates and lowered 1.5".With volvo ic installed.
Joe F Offline
Good choice; while your in there do it all.
Good luck, take your time and all should be well.
evintho Offline
I just pulled the dash out of the '88. There's really only a couple of bolts (maybe 10) that hold it in. The hardest part is disconnecting all the electrical connectors without breaking the clips! Disconnect the A/C and heater hose lines and yank the heater box also. Not much holding it in either. Change heater and evap cores and clean it up real good. Do it once, do it right! Good luck!
Proverbs 3:5
Check out Thunderstang!
I agree, it you got to go in there anyhow, replace the heater core.
