$^^%$&^%$ DARN HEAD BOLTS
wwwtbirdforumcom Offline
Fond an engine to work on and is a 2.3 turbo - I removed the valve cover and I can't get the head bolts to even budge - I was going to send the head out to get it redone - I was full bore into turning it (and I'm a big guy) but those suckers would not budge. Any ideas????
Here is my 1987 TC, Mean look - Glad to be here...
[email protected]
Here is a pic of my baby
[Image: Cumberland.gif]
[email protected]
Dan E Offline
Lots of PB Blaster and a long breaker bar socket wrench....
Dan Eaves
Dan Eaves
REally PBBLASTER? This engine is al oiled up and valve cover just removed - the head is covered in oil....
[email protected]
[email protected]
I use a 1/2" breaker bar that is about 2 feet long, and a piece of pipe about 1 1/2 feet long slipped over the end to give about a 30" long lever arm. Even then, it takes a real good yank to break them loose.
bigred Offline
Just look out for your back,pinched 2 nerves getting mine loose.Just keep using longer pieces of pipe till they break
1988 TC T-5 swap,New Head,Wiseco .030 pistons ,5.5 Crower rods ,balanced ,24x12x3 intercooler,T-3 .60
Ranger Roller Cam,New brown tops.
New 3"cat and 3"single SS exhaust
TurboCougar Offline
Banned
If you have a floor jack remove the lever and slip it over a wrench this will give you a good 2 1/2' pry bar and those bolts will come right loose. Don't hurt yourself.
lmp320 Offline
i went through that yesterday. get a 1/2 inch ratchet, with a hollow bar to pry. those bolts are bitches. the second from the front on the left side took me two busted knuckles to get off. on the bright side, i finally found a good head, which is sent off for a valve job as i type. u are just gonna have pull the hell out of them man, basically.
oh yeah, i think is was a short well 13 mm socket that got it off for me, with a short extension, but whatever it was, IT HAS to have be a 12 star, not 6. the 6 points just slip off. good luck man.
[This message has been edited by lmp320 (edited 03-12-2002).]
lmp320 Offline
i am assuming that u ended up gettin them off.
Didn't get them off yet - going back saturday to get them.
[email protected]
[email protected]
