cjTURBOholic
Nov 2007
Austin, TX
What is everyones opinions on cutting springs
94Lightning
Mar 2003
Springfield, Missouri
cory, did you get that booster installed ok?
1990 LX drag car
1971 Mach 1
1986 GT conv
1990 Mustang GT conv
1986 Turbocoupe
1988 Turbocoupe
cjTURBOholic
Nov 2007
Austin, TX
O yah it worked like a charm!!! It was a S.O.B to put in but it works
Sluggo
May 2004
Huntingtown, MD., USA
I guess that depends on the purpose. They definately get stiffer when cut.
Doug
RDOG
Jun 2001
Ontario. California U.S.A.
My opinion is NO WAY. The ride stinks and the car hops around. For me it was like riding in a blender. If you have the funds, get coilovers.
turbotbird23l
Jan 2008
kennesaw, GA
I cut the springs on my bird and it rides great on a stock set up. The most important thing to remember is safety first when dealing with springs I almost got killed by one when I did mine lol, spring compressors will not fit under the car on a stock set up, I used a tire tool, a pipe and a lawn tractor to get mine out but I would not recommend you do the same the spring shot out and missed my head by 2†no joke. Now you know what not to do the trick to cutting springs is keep them cool when you do it, some one holding a water hose on the cut when you are making it. But that’s only if you use a power tool, make up your mind what your going to use if you do it with a hack saw wd-40 will work great just remember to KEEP IT COOL other wise it will ride like crap springs are heat treated. Just to give you a reference point to go on I cut the front springs 1 down from where it stops at the top just rest the blade on that for a guide. The back ones I cut them 1 and ½ coils down from the same place I did the front. The car now rides level with the top of the tread of the tire (stock tire and snowflake wheel) just tucked under the fenders it looks and rides great. If you need anything just email me and I will do my best to help, [email protected]
p.s. it took me about 5hrs to do it to mine
JBrandonDavis
