cutting out EGR system
Boostbird16 Offline
what would happen if i cut out all the EGR tubes and simply plugged them up? would this mess up the computer or make it run incorrectly? I saw a guy at the track without any of his and i wonder what all has to be done to make the car run right after this happens.
Adam Rafferty
Glenn 88TC Offline
Why not just pull the vac line off it and plug it? This would eliminate the egr set up and still be made functional for emissions testing.
Glenn 88TC
current mods: ported & polished big valve head(1.89/1.59), ranger roller, custom upper and ported lower intakes, t3/t4 turbo, powerstroke intercooler mounted full size, 60mm throttle body, R.C. Engineering 42lb. injectors, MSD 6al, MSD Launch Control, MSD 8.5mm wires, K&N filter, Walboro 255HP pump, Kirban adj. fuel reg., ATR header, full 3" exhaust with Dynomax Ultraflow muffler, Star stage III clutch, Hallman boost controller, Flex-a-lite adj. temp switch for stock fans, Weld Draglites with M/T ET Street 26x11.5/15
87 Merkur Xr4ti - daily driver
NO TC and NO headaches.
Boostbird16 Offline
so the basic purpose of the EGR system is for emissions testing? does it restrict the flowing capabilities? i don't see why else he would have done that.
Adam Rafferty
Glenn 88TC Offline
The egr recirculates some exhaust gas back into the intake tract. This will help emissions and bring hot air into the intake. The second thing is why it was bypassed on that car at the track. If you just pull the vacume line off(plug the vac line) it it will not open to allow the hot air into the intake thus bypassing it wihtout removing it. You will need it for emissions testing.
Glenn 88TC
[This message has been edited by Glenn 88TC (edited 03-23-2003).]
B_Lieder Offline
According to my book
"How to Understand, Service, and Modify Ford Fuel Injection & Electronic Engine Control"
It has an article in the tuning for performance and economy section, "Remove Egr??"
It says, The engine-control shuts off EGR under high performance conditions, also at idle, and cold operation.
The rate of fuel injected and the spark advance are calculated for the EGR under part-throttle conditions. If you block off the EGR, you stand of good chance of experiencing knock and wasting fuel. You might even reduce your power output, aswell as dirting the air.
Whether or not that is 100% true....i don;t know. But, you can make the above assumption yourself.
Hope this helps
Bill Lieder
1988 TC stock until summer
Bill L
Boostbird16 Offline
so what the guy at the track did, was mainly for racing only. meaning that his isn't street legal. Well, i learned something today. thanx Glenn
Adam Rafferty
Boostbird16 Offline
so the egr actually helps the system run better? i don't understand how you could experience knock AND waist fuel though. I guess i'll forget about the whole thing and keep my current EGR equiptment on.
Adam Rafferty
Red_LX Offline
Hm. Well, when I put the longtube header on my '90 LX, it had no provisions for the EGR so I just took the pipe off it, removed the gasket, replced it with a sheetmetal plate I made to block it off, and left it plugged in. Hasn't caused me any problems...
Garrett Hunt
Moderator, 2.3L & Turbos Forum @ forums.stangnet.com
'87 Thunderbird Turbo Coupe
Windage tray, crank scraper, P&P head, RR, ARP head studs, P&P intakes, 60mm TB, Accel AFPR, Bob's log, T3, big FMIC, blow-thru VAM, Forge BOV, 3" exhaust, UPR shifter, gauges, etc.
My Turbo Coupe
Mr.T Offline
This is definitely one of those YMMV type mods. If you do a search on Turboford.org, you will see that many people have differing opinions on this one. For the most part, if you remove it, you will eventually notice slight pinging at part throttle at least sometiem in the future. Ambient temps, fuel quality, ignition timeing, carbon build-up in the cylinder, etcc... will all play a role.
1985 T-bird TC, 5Spd, Black (The Project)
1985 T-bird TC, 5Spd, Black (The Project II)
1986 T-bird TC, 5Spd, Black (The Show Car)
1986 T-bird TC, 5Spd, Silver (The Daily Driver)
1989 Mustang GT, 5Spd, Black
1986 T-bird TC, 5Spd, Black (The Project Car)
EGR valve is closed at WOT, and has NO effect on WOT performance. I personally see no reason to remove it. If you live in an emissions area that measures NOx emissions, you will likely flunk the test without an EGR system.
